1 - 4 of 4 Posts
Is it common for a gas cap to leak? I may have overfilled it the other day, but I wanted to see what other people have experienced. Thank you.
Sent from my SM-N950U using Tapatalk
I have only had mine leak/seep once. I had over filled it. Drove for a couple of miles, snicking through the gears, solved it self.
I probably overfilled. The rubber gasket is there, but it may be cracked up some. It is a keyed gas cap, so not sure if there is a replacement seal.
1 - 4 of 4 Posts
