1 - 4 of 4 Posts
Does anyone have any information whether the Kawi GPS mount for the 660/665 Gamin will work with the new 390 model?
BOTM Winner, February 2016
All the Gamin's have a slightly different form factor, so unless you are replacing one in the same model line, its not likely to fit. Best to just go with the RAM mount and the specific mounting plate for the Garmin.
I picked up a couple of different mounts, any they were only like $15 each. The base RAM mount is more expensive, but you can hookup any of the various mount plates to it.
Ram mount
I know Ram mounts are the easiest, but I want to keep things off the bars if possible. I intend on fabrication a yoke mount (similar to Kawi's) and want to mount between the radio and the gas tank.
I am unsure how the Kawi system works and the dealer does not have one to inspect.
I am most interested in how the Kawi accessory integrates with the stock system. How is the power rounded (through a cable of through a wire)? The wires on all current models are mini-USB connections.
1 - 4 of 4 Posts
