1 - 9 of 9 Posts
Discussion Starter · #1 ·
I am almost 100% that i need a fuel pump. Are there other options out there aside from oem from the dealer?
If not ill be getting a used one
Discussion Starter · #3 ·
Doesnt cycle or prime when ignition on. Doesnt run just cranks. Been sitting over a year in storage. The fuel in tank was dark yellow and rancid. I had a reading of over 12v at the connector on the pump (the one in the tank) . Leaves me to assume it needs a pump
Since you ordered a replacement, might as well install it, but if that one does not work, post back and we can do a little troubleshooting.
Discussion Starter · #8 ·
Sounds good . I appriciate it. What kind of oil is recommended for these bikes? I usually put 4t mobile 1 or castrol in my zx10r
Discussion Starter · #9 ·
Just an update : looks like the fuel killed the pump. I removed all the old fuel filled it with new gas and sea foam and installed the new pump. She runs like a champ and really smooth
1 - 9 of 9 Posts
