My 98 1500 classic has a fuel problem, I believe. The only way I can keep it running is by cupping my hand over the carb. When I take my hand off the motor stumbles and dies. There is gas squirting into the carb body when i blip the throttle. However the motor will still die if I do this even with my hand cupped over the carb. I pulled off the gas tank and tried to listen and feel the pump running but got nothing. I even pulled off the fuel pump and hooked it to 12 volts but still nothing. If its bad is it fixable or do I have to buy a new one. Are there any good cheaper than OEM fuel pumps available that will work. Kawasaki OEM fuel pumps are expensive. I did take apart the fuel side of the pump but I don't see that to be the problem if the fuel pump motor is shot. Please help if you can
