1 - 4 of 4 Posts
Hi all,
Looking for some help...
Having an issue with fuel pump not coming on. Pump works when hooked up to 12v, but not workin when ignition or cranking. Am i right in sayin that it needs the 2 wires going to each of the coils to work the pump correctly?
I had put a wire goin from ignition to pump so that it came on when key on. But not sure thats wise ?
Bearslayer,
Many thax for ur reply. ive just earlier found the problem😁 was a dodgy 4pin connector to the pump. Opeed it up abd cobbected it and now worki great.
There is a type of relay connectd to 2 wires. It has 6.4 stamped on it? Is that type of relay?
not sure , I know that on most scoots unless there is a massive switch there is usually a relay.
I have had several problems with my horn relay. so I usually check them and connections first.
1 - 4 of 4 Posts
