Not sure if this will work or not but here is a link to a Facebook Group "Kawasaki 1700 Voyager Owners"
I'll see if I can Cut and Paste it here - About 15 pictures with comments.
Well I did the Fuel Filter change in the Fuel Pump - All I can say - Yuk. Not a bad job but the filter was disgusting - Even had some bugs in it.
Edit - I went back and added comments to each picture to maybe help explain the process.
240185
This picture is to show How I propped up my tank while I did the job.
240186
Upon removing this plate and fishing the fuel pump with float there will be a small amount of fuel leakage. I did sop up about 3 paper towels.
Note this is also how it looked when I was done. The service manual suggest a star tightening pattern of the bolts at 87 in/lbs torque. (Oh and Blue Loctite)
240187
I did not remove the rubber O-Ring - just wiped it off.
240188
The filter is located at the bottom behind the two wire connections by mounting plate. Pay close attention as to how the wires route. They need to be disconnected and taken out to the guides to disassemble the pump.
240189
240190
You need to remove the little plate with the 3 screws. You will also need to fish the wires through the little black clip to remove the plate.
240191
Once the top mounting plate is removed - the fuel pump is in two pieces and slides down on the two metal rails. You will need to do a little prying to release the top part from the bottom. There is an O-ring. I pulled it off to allow the bottom to come off.
240192
Discussion Starter #2
More of Fuel Filter Replacement
This shows the point where I pried to get it apart.
240193
As it came apart I realized I had to release the wires from the clip. You can see the O-ring lower left.
240194
240195
These two slip on electrical connectors must be removed. I took pictures to be 100% sure which one went where. Not sure what will happen if you reverse them - I really don't want to know.
240196
This is what the fuel pump looks like after removing from the bottom housing. Note that you have to remove the two electrical connections to get the pump to lift out.
240197
The filter all Yucky is tucked in the bottom. Pay attention to the orientation of the filter Cause the new ones gotta go back in just like this.
240198
New one on the right. (duh) you just stuff the edges down in the housing. There is a nipple on the other side that kinda sits in place.
240199
Filters are available here - https://www.highflowfuel.com/i-23893476-quantum-fuel-pump...
Credit for this goes out to a Bruce Shep a Service Manager out there somewhere. He discussed this in a forum somewhere on the internet. Thanks Bruce.
As stated elsewhere - this is not in any manual or on a maintenance schedule. Your dealer may or may not know this is possible.
I hope this gives some guidance to others to pick up your wrenches and get to know your motorcycle.
How old is that bike and how meany miles on it?
If you click Mike's link to Highflowfuel.com, you'll see they recommend yearly replacement of the strainer. $14.95 gets you three of them. Mike's latest (of 3) Voyagers is a '14.
