1 - 5 of 5 Posts
A while back I replaced my rear tail light with an clear alternative all in one led. It came with its own flasher relay and has worked fine since it was installed. I have recently replaced my front turn signals with led replacements and they stay on all the time with the key on. I have tried everything to make them go off while they are not engaged to signal with no luck. I am running the stock flasher for the front but my thinking is that if it was the flasher they would not come on at all opposed to staying on all the time. Anyone got any suggestions?
I think they stay on as marker lights. I don't have front lights right now (turn signals) so I can't confirm. I will be installing them again soon, as the PO took them off.
^^The fronts are a dual filament bulb and are on as marker lights all the time. They flash the second, brighter filament when the turn signal is activated.
1 - 5 of 5 Posts
