1 - 3 of 3 Posts
I replaced the front springs on my 08 900C with progressives (without removing the forks, just opening from them from the top) and thought there was a problem; I have edited my initial post, since I test rode and discovered everything is fine. Huge difference I ride quality!
Crazyj, can you share the link on your mod? I cannot find it in your history. Also how much drop did you have after installing? I'm 250ish and with 2" lowered rear, I might fear of things getting too low.
THANKS!!
Hey Headstill, I'm not sure what you mean by the link, since I didn't record the actual work. I used Progressive springs with the spacers that came with it (PVC pipe cut to 3" each). as far as I can tell, it didn't lower it; at least that wasn't my intention. I will not be changing anything in the rear. I'm 200 and 6'1" and personally wouldn't want it lowered too much. Hope this helps.
1 - 3 of 3 Posts
