1 - 16 of 16 Posts
It's me again guys. Sorry. I'm trying to learn as much as I can on this bike on my own and I have found a ton of info but like usual there are a few things I can't get my hands on.
It may be in my head but since our 250 mile 2 up trip this weekend, somewhere along the journey I started feeling or think I started feeling some additional and what I would consider excessive vibration through the handle bars. It is especially noticed when going over slow speed small bumps.
Also, and i'll start by saying I never make a habit of doing this, but if I take my hands off the handle bars it immediately goes into what I would call a death wobble, especially when decelerating and there is weight on the front end. As soon as I grab the bars it stops but I still feel it through my hands and arms a little.
I have ridden many motorcycles and I have never had one I can't take my hands off the bars and feel comfortable doing it. Even the vibration is a little scary. Makes me feel uneasy likes somethings up with the front end.
I was watching a review on a Goldwing one time and the guy mentioned it had this problem and there was something he said probably needed to be replaced up front that was more then likely wore out. It was years ago when I watched it and I cant find it now.
Anybody know what the part is called or if this bike has it at all.
Discussion Starter #2
Sounds like my issue could be from steering bearings. I am not a mechanic and have very basic skills and surely not the correct tools to do this job. I think it may be too large of a task for myself. I'm going to price at least checking them at the dealer and see where that goes.
There are a number of things which can cause this, but it's fairly common to all makes and manufacturers. It's a function of geometry.
1. Make sure your tire pressures are correct.
2. If your tires are worn and cupped, it can contribute to this issue.
3. Add in some preload to the rear shocks. I know it sounds counterintuitive, but what goes on in back affects the front.
Finally:
Jack up the front end of the bike from under the motor, getting the front tire off the ground. Make sure the bike is steady and solid - then go around front and push/pull the front wheel/fork assembly back and forth along the centerline of the bike. There should be zero play.
Now move the handlebars back and forth from stop to stop. They should move freely with minimal resistance. Worn headset bearing races will often brinnell (dimple) in the straight forward position; as you go through the harmonic speed for a steering wobble (usually 15-25 MPH, depending on the bike) the dimple amplifies the wobble. The dimple will fell like a detent for the straight forward position. Bearings MUST be replaced if they are brinnelled - it is unsafe to ride a bike when the bearings are worn like this.
My guess, based on mileage, is that it's a combination of the first three things, unless the previous owner was a big guy doing lots of interstate miles. Headset bearings are pretty robust these days - not at all like the stuff we had back in the 60's.
Trust this helps.
Thanks a lot for this response! I will check all three of these items tonight. To the eye the tires look fine but i'll check them more closely. They don't look bad but i'm pretty sure they are the tires that were on the bike when the previous owner purchased it. He put less then 1000 miles on the bike so there is a chance they have went bad from sitting.
As for the preload, would I be correct in that you are referring to how much air pressure is in the rear shocks? I'm pretty sure you are. I know this sounds silly but I am pretty nervous about adjusting the pressures back there which is why I haven't done it yet. I know you can royally screw up the bike if you get those pressures wrong or uneven. I am going to have to figure out and invest in the proper tools to both check and fill them up or release air depending on what the issue may be.
I will definitely look into all this very soon! thanks again!
If I had to place a bet - it would be shocks. Geometry changes when you're 2 up. You could probably ride it now and not have any wobble. A fully laden bike will be less stable - especially if there's quite a bit a weight over the rear wheel. I built a motorized bike as a kid - but the motor over the rear wheel and it was damned near unrideable.
And you're welcome!
Wow I bet lol. I hope it is something simple in my case. I'm going to take a good look at it all tonight. Wish me luck lol.
Same problem with letting go of bars at low speed. First time after getting new Metzler tires, was told to raise tire pressure to 42,that worked but now going very slow wheel goes back n forth like going over groves in road,put on 700 miles no problem but tire pressure 32.will raise to 42 again n try.
My wobble problems on my 08 Nomad turned out to be a lack of grease on the lower steering head bearing from the factory. Cleaned the bearing, thoroughly greased the bearings and races and reassembled per the service manual. No wobbles at any speed, hands on or off.
I had that problem on my 07 Nomad; slowing down, light touch on the handle bars and the front would wobble. It went away when I put new tires on the bike.
Dude, my 900 had the exact same symptoms! Find a way to get your front end off the ground and do the bounce test. Once the front tire is up, center your bar and let gravity pull it one way. If they bounce back from full lock, the steering head bearing is too loose! Mine bounced and swung to the other side. I then read up on how to tighten the bearing. Once that was done, the vibration was virtually gone! The grips were not shaking in my hands anymore! It took a few attempts to get it right; but once it was done, the bar would just fall to full lock and stay there.
Hope this helps!
And you're welcome!
Yeah, the bike will be less stable, but the front shouldn't wobble. I rode a KLR650 for a while. It was my only mode of transportation and when it came time to grocery shop, I strapped a milk crate to the rear. I would load the crate up with 2 or 3 12 packs of pop and all my other goods. That rear was sagging bad. The bike was still ridable, but it had horrible understeer and it was top heavy. Never did experience any front end wobble from it.
I was on my second set of replacement tires when we found the lack of grease in the steering head. I would go after the steering head bearings before doing tires.
I just replaced my steering stem bearings about a month ago. My problem was getting the bike to turn off straight. Basically had to "break" the handlebars past where you would be comfortable turning, then recovering past it. My dad just had a similar issue with his front end having a bit of a wobble at higher speeds which seemed to be his front tire being worn.
From my experience, I'd say if it feels like your front wheel is locked in position at low speeds, then it's probably your steering bearings.
Try balance beads and ride on tire sealant together, my 05 1600 I could not trust,out both in and smooth as a baby's bottom.
On my bike I had alot of noise and vibration and the tire was cupped it would make more noise around corners.
But as others stated check your wheel balance and put your bike up on a stand and check your steering for notchyness or any play in the steering stem.
Kawi seemed to be notorious for not greasing the lower steering bearing at least on the mean streak so many people have had to replace steering bearings at a very early time because they would rust and get notchy. I got my bike with 5000KMs so knowing this info I checked my steering for play etc which it never had then I carefully installed a grease Zerk keeping the shavings from going inside the steering head with a vacuum as i was drilling and pumped it full of grease till a bit came out the top and bottom ( over 100 pumps of grease btw). I will take it apart if i feel any notchyness.
I put in balance beads and ride rite in tire,took off heights and wobbles gone, smooth as can be.
1 - 16 of 16 Posts
