Bit of a long shot, but does anyone (in the UK ideally) have a front caliper mounting bracket for a 1996 VN1500 Classic ? Parts book shows it as a "Holder-Comp-Caliper, Fr, LH" part number 43044-1117. Its the bit of the caliper assembly that actually bolts to the fork leg. One of the mounting points on mine has finally given up and the threads have stripped. I'm also looking to helicoil it, or even weld it up and re-drill/tap, or even tap it oversize and bore out the holes in the fork leg - but a good second hand part would be a lot simpler !!
