61 - 77 of 77 Posts
After much pissing and moaning on my part about my ticking engine (the dealership service guys walk the other way when they see me coming), and no one wanting to fix it, I decided to tackle it myself. I’ve never done anything of this depth to a motorcycle before, and it wasn’t as hard or time consuming as I thought it would be. To give you an idea of my skill level, I have done a lot of minor repairs to cars. Water pumps, alternators, starters, power steering units, radiators, and such, but no real internal work (cams, lifters, pistons, etc.). This job took me probably 15 hours over 2 days.
If your bike is just ticking for a few minutes after start-up and then clearing up, I wouldn’t bother with this. Mine was persistent and at times loud enough to be heard over my Hardkrome pipes at moderate speeds.
If you don’t have a shop manual, I suggest getting one. For everything in this job, this manual should work for any year. I’ll post some pics, but I suggest taking pics of your stuff before taking it apart so you can see how it goes back together. I’ll refer to left (driver’s side) and right (passenger side).
The parts I ordered: 8 HLAs, 2 intake rocker shafts, 2 exhaust rocker shafts (unnecessary), rocker cover gaskets, 2 spark plugs.
I drilled 1mm holes in my rocker shaft screens (pic below). If you’re ordering new rocker shafts, know that only the intake shafts have screens, so replacing the exhaust ones is probably pointless.
Before you ask, yes, you do have to lower the engine to take the rocker covers off. I tried briefly to take just the front one off, but there’s one bolt that won’t come out far enough to do it. The way I lowered it, you don’t have to completely remove the down tubes, the radiator or the exhaust, or even the right floorboard.
Apart from the usual wrenches & screwdrivers & stuff you’ll need a motorcycle lift (I have the $70 Harbour Freight one), a front wheel chock, and probably 2 torque wrenches, one for in-lbs. and one for up to 80 ft-lbs.
I also took this opportunity to replace the spark plugs. The engine has to be lowered to do the rear one and I don’t want to have to do this again anytime soon.EDIT Disregard this. The engine DOES NOT have to be lowered to change the plugs. It can be done with an extension and a universal joint.
First, stand the bike up in a wheel chock. You’ll want it upright.
As you take things apart, lay them out so you know what goes to what. I even used masking tape and a Sharpie to label some of the bolts. Too many times I’ve had that stray little bolt or whatchmahoozit left over when I was done. Probably don’t want that here.
Remove: Seat, fuel tank (this is the kind of stuff where the manual comes in handy), the top piece of the headlight nacelle (where applicable), side covers, left floorboard (put the bolts back in to hold the shift lever on). My crash bars poke out over the front rocker cover, so they had to come off. Either way, the bolts that hold on the bottom of the crash bars (1 on the right, 2 on the left) will have to be loosened.
Drain the coolant.
This wire retainer is on the left side of the frame by the neck. Take it off.
This little guy is on top of the frame. Disconnect it. The ground wire, too.
What we’re doing is freeing stuff up for when the engine is lowered.
On this guy, take off the 2 longer hoses and disconnect the electrical fitting. The hose to the air box can stay.
Remove the top radiator hose and unbolt the fill assembly.
Remove the overflow tube, the hose on the bottom of this unit, and lay it back behind the tank bumper as shown.
Remove the exhaust bolts that hold the exhaust to the main frame, behind the down tube.
Remove this cover on the left side (all 3 pieces).
Remove the top motor mount. Take the top bolts out of the frame so the throttle cables can move when the engine is lowered. You can leave the mount hanging by the wire that runs through it.
Remove the radiator cover and the top bolt that holds the radiator to the frame.
On the left side of the frame, above the rear cylinder there’s a small hose in a plastic retainer. Remove it from the retainer.
Now it gets interesting. Loosen all down tube bolts.
Put your lift under the middle of the bike, ahead of the down tube joint. Go in from the right side. Make sure the lift is under both down tubes. Jack it up “a bit”
Remove the top down tube bolts. Remove only the front down tube bolts on the bottom. This will be the “hinge” that will help everything line back up.
The frame where the top of the down tubes are has protruberances (shown), so you have to pull out on the down tubes. You may have to loosen the crash bar bolts some more.
There are 2 large bolts by the rear pulley (where the drive belt is), one below it and 1 above it & to the left. They have to come out and they’re kind of a bitch. The nut for the lower one is below the oil reservoir. It’s blurry in this pic (sorry).
Now you’re ready to lower the engine. Just lower it a bit and look around to make sure nothing’s hanging up (wires, cables, hoses, etc). If it gets to where it won’t lower enough, check the drive belt. If it’s tight on the top and loose on the bottom, slowly pull the clutch lever. You want to lower the rear cylinder about 1 inch. The front will go down farther because of the “hinge”. If nothing got hung up, there shouldn’t be any wires or hoses stretched tight.
Remove the rocker covers. I made a 1-10 chart for bolt location on each cylinder and labeled each bolt, since there are 2 different lengths and I didn’t want any mix ups.
Here’s what it looks like with the rocker covers off . Sorry, I didn’t get a pic of it lowered with the covers still on.
Now, I did 1 rocker arm at a time to avoid mixing anything up. But I’d take all 6 of the top bolts out. That way, when you pull the little plug thing out the shafts will come out a little with it (the little curved wire thing at bottom center here).
Pull the shaft out, wiggle the rocker arm out and do what you’re gonna with the HLAs. I figured if I’m going to this much trouble, I’m just replacing them all. Here’s a shot with the rocker arm and some of the HLAs, old and new. The HLAs can just be pulled out with your fingers, or some pliers. The new ones just push in.
Here are the old & new intake rocker shafts. Note the 1mm hole in the screen on the new one. The size of the hole doesn’t have to be exact, but I wouldn’t go any bigger than that.
Get the new (or confirmed good) HLAs put in, the rocker shafts and rocker arms put in and the bolts torqued (again, the manual is handy for this), and you’re ready for re-assembly.
Put the rocker covers on. I replaced the gaskets, but the old ones still looked good. Torque the bolts down.
Raise the lift enough to get 1 of the bolt holes by the drive pulley lined up and put that bolt in. A little gentle persuasion may be necessary, but be careful.
Next, I raised the lift enough to install the front down tube bolts. Next, the rear down tube bolts. Don’t forget to tighten the ones that were loosened but left in.
Now the other hole by the drive pulley should be lined up. You can push a screwdriver covered with an oil rag in & nudge it a bit if needed. Put that bolt in.
Congratulations, the hard part’s over. Go through, put all the hoses & electrical fittings back. Check & recheck that everything’s connected and that the hose clamps are tight. Fill the coolant. I changed the oil at this time, but it’s not necessary.
When you start the bike, it’s gonna clatter & tick until the HLAs fill with oil. I let mine sit at idle for about 10 minutes and then took it for a short ride. By the time I got home, the ticking was gone! That was last night and I hope it stays that way. I’ll keep posting updates.
If anything here is unclear, incomplete, or just wrong, let me know and I’ll update this post.
Thanks to V2Kman for input, as well as others who have joined in the many discussions about this.
Is there a mileage this is prevalent at?
Ok,
Act like I am dumb and what is are HLA's??? The ticking sound that I have been made aware of by local Strack repair shop is that this model, classic LT has a plastic part in the oil pump.When it goes out you start getting the ticking or loud tapping noise. It gets louder as the pump starts to give out and the tapping in the upper part of motor is the sound of the bike not getting oil up there. They have seen it before. Eventually if you keep driving on it the engine burns out due to lack of oil in the upper part of engine due to pump failure, thanks to the cheap plastic part in oil pump. That is the 2000 classic LT. Of which I have one unfortunately. Quite stupid on Kawasakis part to due things the cheap way!!!
BOTM Winner, April 2016
Ok,
This description from these mechanics is not even close.
HLA'S = Hydraulic Lash Adjusters.
They're at the top of the engine between the rocker arms and the valve, and they use oil pressure to "pump up " and take up any valve lash.
There is a crap oil screen on the rocker shaft where the oil enters that gets plugged, and then the HLA's loose their prime and collapse, allowing an excess of lash in the valve train which is the ticking.
You really need to read this whole thread from the start, it explains this perfectly in many ways, and goes on to explain very well how to fix it.
There is a bullshit oil screen on the rocker shaft where the oil enters that gets plugged, and then the HLA's loose their prime and collapse, allowing an excess of lash in the valve train which is the ticking.
Without having to read it all, is it something to fix ahead of time due to mileage or only worry about it if you get it?
Well... I can't recommend enough that you read the whole thread to really understand what's going on.
But, it's not really a mileage thing, rather, an oil change interval vs long stretches of riding thing.
More often than normal oil change with quality oil will go a long way at keeping this issue from happening. But it will happen eventually.
Ok, got it and will do
Lawn mower
if it has hydraulic lifters, some ATF fixes the problem usually in 3 min.
Dirty oil problem, learn to flush engine.
I hope you had fun.
I see hydraulic lifters.
If you don't get you engine clean, you'll hear lifter noise again.
ATF fixes lifter noise with about 95% sucess, maybe 99%
I hope you had fun.
I keep seeing the thing about ATF ... but how much do I put in? How long do I run it like that? Do you drain all the oil and just run ATF for a bit, then drain that? What is the protocol with the ATF and Seafoam? Thanks
Just an FYI for anyone who comes across this thread and is considering buying these HLAs and other various parts to do this to their V2K ... the cost of these little HLAs (May 2021) is now $80 per actuator, and about $54 per exhaust rocker shaft ... so without even considering spark plugs and gaskets, you'd already be into this for more than $750 ... for some that might not be a big deal, but for me it would pretty much be a solid nope!
Also one more thing ... I just got done taking the bike apart to drill a hole in the end of the intake rocker shafts (gold screen) as described in the original post -- I can say that it had zero effect on the clacking, knocking sound my engine makes. I don't know if it's even louder than before, but it definitely did nothing to quiet it down. And all the HLAs still looked brand new. So probably a waste of time and effort for me, but it must be something else on my bike. Just sharing my experience. The interesting thing is that those filter screens are at the "end of the line" when it comes to the oiling at the rockers, so I guess I don't really see how drilling a hole in them or getting rid of them entirely would make any difference in the sound coming from the HLAs and/or rockers. The oil goes first through the shaft, out to the rocker arms, down to the HLAs, and then continues on to the end of the shaft where these screens are. It almost seems like maybe they exist to help keep a certain amount of pressure inside the rocker arm shaft? I don't know, either way it was a bust for me.
‘95 Vulcan 800 Custom
Drain the coolant.
My God man! That was one helluva lesson in self reliance and an how some shops can encourage a lazy culture in their workforce. Kudos to you man!
Who has tried an AMSOIL engine flush, AMSOIL 20W50 and AMSOIL oil filter? Could that potentially help to get rid of the ticking and knocking for a while? I'm due for an oil/filter change and plan on trying this combo.
I'm not the expert here ... but from the amount of reading I've done on ticking motorcycle engines and potential remedies, it's usually ill-advised to run a higher weight oil simply because the oil passages in the top end are extremely small, so usually it's a matter of trying to thin out the oil, as opposed to running a thicker or more viscous oil. This is why most will start with a full synthetic 10w-40, then maybe use Marvel Mystery Oil as an additive, and even sea foam. These are all safe, proven remedies to help with quieting down things that are noisy in the engine. But to each their own ...
Some (myself included) have also done ATF flushes, which is quite common. Drain oil, fill with ATF fluid, run at idle for 15-20 minutes, drop ATF and remove filter. Then refill will desired oil and a new filter. I can't say I noticed any difference in the sound of the engine, or that the ATF did much in the way of cleaning (it was mostly still red colored when I dropped it back out), but my bike is still pretty low mileage and has had a few oil changes prior to 5k miles, so there hasn't been a lot of time or use that could have resulted in a bunch of gunk and buildup in the engine. Although others I've seen with higher mileage bikes have dropped the ATF and it was virtually black when it came out, meaning it was doing its job of cleaning all the deposits in the motor. Just a thought ...
My bike has 42k +. I know the previous owner took very good care of it. Funny you should mention 10W40 as I have been torn between the two different grades. Lots of big V-twin riders use 20W50. If I were to go with any other oil I would use 10W40, but with Amsoil, I will try the 20W50. Worst thing that happens is I have to change the oil again. I read a lot about ATF, I just don't want to waste 5 litres of ATF just to de-gunk my engine. But I have no doubt that it works the same as a good engine flush.
For sure ... I mean the main difference is that the 20W-50 thing comes mostly out of the Harley community -- air-cooled bikes vs. the water cooled Vulcans. The air-cooled bikes will naturally run hotter, but regardless a lot of guys base it on the temperature they most often ride in. And I definitely get not wanting to waste oil, I think it was around $14/gallon at Wal-Mart, and I saved it even after I drained it out because it was still so clean ... I'll find a use for it, but it was worth a shot. But you'll have to let us know how the 20W-50 experiment works in your bike ... I'm always open to trying new things in an effort to quiet things down and make them run better. Cheers!
After an engine flush and an oil/filter change, the ticking and knocking are gone for now. I rode the bike for an hour and repeatedly did all the things that previously would make the bike start ticking and knocking but it did not come back.
This is what I did.
Amsoil engine flush.
I put it in and let the bike idle for 15 minutes. During that time I did shift gently through the gears a couple times. I wanted the product to work itself everywhere and I thought this would help. The oil came out very dark, very dirty even though an oil change was done a short while ago.
Amsoil 10W40 100% synthetic metric motorcycle oil.
My first thought was to try 20W50 but as I was informed above, this bike is not an air cooled Harley so the 10W40 made more sense.
Amsoil oil filter.
This filter is said to filter down particles as small as 20 microns. So I am hoping that it's true and that it helps keep those filters in the HLAs clean.
What was in the bike previously was Shell Rotella T6 5W40 synthetic oil and a Fram oil filter.
Fingers crossed that this lasts, the engine sounds very happy and shifting is smoother than before.
EDIT: still no ticking after a month and plenty of riding.
EDIT II: After two months the ticking is back, comes and goes. Highway riding makes it go, stop and go traffic in the city makes it come back. :confused:
2006 V2K Classic LT
My bike doesn’t tick much at all at 33,000 miles. Here’s a video of it
61 - 77 of 77 Posts
