Theoretical Top Speed is 106
Unless I did something wrong or this site (
http://www.dansmc.com/mc_software1.htm) is incorrect the 17 tooth sprocket will up each gear's top speed by about 5 MPH. I'm thinking about doing the same thing at my 500 mile check up because I do feel like I have the revs a bit higher than I'd like while on the highway and the 17 should definitely save some fuel.
Here's the 16 and 17 comparison as well as the 42 vs. 40
Primary Gear 2.652 Front Sprocket 16
Rear Sprocket 42 Rear Wheel Dia 24.92
1 Gear 2.571, 33.13752671979043 MPH
2 Gear 1.722, 49.47536654853728 MPH
3 Gear 1.333, 63.91341425099865 MPH
4 Gear 1.125, 75.73029439696106 MPH
5 Gear 0.961, 88.65409073525619 MPH
6 Gear 0.851, 100.11349141783924 MPH
RPM 8000
Primary Gear 2.652 Front Sprocket 17
1 Gear 2.571, 35.208622139777326 MPH
2 Gear 1.722, 52.567576957820854 MPH
3 Gear 1.333, 67.90800264168605 MPH
4 Gear 1.125, 80.46343779677112 MPH
5 Gear 0.961, 94.19497140620969 MPH
6 Gear 0.851, 106.37058463145418 MPH
RPM 8000
Rear Sprocket 40 Rear Wheel Dia 24.92
1 Gear 2.571, 34.794403055779945 MPH
2 Gear 1.722, 51.949134875964134 MPH
3 Gear 1.333, 67.10908496354857 MPH
4 Gear 1.125, 79.5168091168091 MPH
5 Gear 0.961, 93.08679527201897 MPH
6 Gear 0.851, 105.11916598873118 MPH
RPM 8000
Disclaimer: I'm new to motorcycling and not too much of a gear head so I may have messed up some of the figures.
