1 - 4 of 4 Posts
98 1500 classic
Rear cylinder, top left side. Looks to be a 8mm flange bolt I'll need to remove to pull the hose/fitting out the hole. Replace the -o- ring and reassemble. Looks very tight, hope there's room. Anybody else ever tackle this issue?
Discussion Starter #2
Well to all those who viewed.....thanks
With a good 12 pt. 8mm wrench and loosening up the carb (gives the needed access for the wrench) I got it out. Looks to be the following: ID 11mm, od 15mm, thickness 2.54mm, measured with calipers. Bolt was very long, left just enough space to pull the "plug" out. O-ring will be here wed. Shall be fun to re-install.
1 - 4 of 4 Posts
