1 - 1 of 1 Posts
Banned
Has anyone here ever used Evans Waterless antifreeze in their bikes? I used it in my Ford Power stroke Diesel I used to have and it was great stuff. You purge all the water out of your cooling system first then fill it with the Evans waterless coolant. It is warrantied for the life of the machine you put it in. It also runs with Zero pressure in the cooling system therefore eliminating blown hoses and leaking etc... You drill a small hole in the rad cap after this fill and the system runs zero pressure. It worked fabulous in my truck and was thinking of doing it for the bike. I still have a gallon left from when I did the truck of the Evans Plus but figured I would run it past everyone here to see if anyone has tried it yet.:confused:
1 - 1 of 1 Posts
