hi all, so being new to the Lake Michigan area, I unintentionally left my 92' Vulcan VN1500 sit for a year and a half and the climate here just rusted the bike, sweat, cold to hot days...it was bad!
So got a new battery, starter won’t turn, rear tire locked up when in 1st gear. (bike rolls n neutral). I put WD40 into the cylinders overnight. Pistons Now move when pushed. Starter still froze or gears / internal chains and the like still rusted.
QUESTION – Can I pour WD40 into the crankcase / tranny / clutch, roll it back and forth it in 1st gear to lube things, and drain after a day or so?
Will that product hurt any seals? Anyone had luck reviving an engine after this issue using this method?
