1 - 4 of 4 Posts
Good day all.
I have a question regarding my 2009 Nomad 1700. I have only had it a few short weeks. Not long after I purchased the bike I had the ECU replacement completed. But prior to that I didn't have a lot of ride time on the bike.
Since the ECU replacement, the engine vibration during acceleration has been more pronouned and there is a definite banging when the cylinders fire. At first I thought I picked up some bad gas but now that I have been through 3-4 tanks that cannot be it and I have tried different brands and octanes. It does smooth out as engine revs increase and engine load decreases.
Not having a lot of time on the 1700 I am curious as to what others' experience is. Should this engine be smooth as butter or is this normal for this high displacement monster.
Any advice would be appreciated before I take this thing back to the dealer.
There should be no "banging" sounds coming from the engine. I'd get it looked at
Good day all.
Just curious as to what RPM you are going up to prior to shifting. I see a bit of shuddering if I shift too soon and lug the engine. I normally short-shift from 1st to 2nd, then all the other gears I take it up to at least 2500-2700 RPM before shifting.
You know, without a tach I am not sure. Certainly there is shuddering when lugging the engine and I understand that. But this would be at an rpm associated with 50 mph in 5th gear as an example and it happens in all gears, which I wouldn't expect in 1st, 2nd, 3rd.
I take two major roads to/from work that are 45 mph and I spend about 2 miles on each. I get shuddering when I try to accelerate in 5th gear at those speeds, some shuddering (vibration) in 4th.
It is that coupled with the knocking that has me concerned.
1 - 4 of 4 Posts
