Engine code 62
50 views 3 replies 3 participants last post by  BlueRibbonRM
#1 ·
Hey all, just bought a 2022 vulcan S 650 with 6k km on it and I’m getting a code 62 with the engine warning light staying on. Anyone know anything about this?
#2 ·
There's not much info on it. All I can give is things to check. There's a STRONG WARNING to don't remove the sub throttle valve actuator. On a couple of postings I've found the people had used a pressure washer to wash their bikes.
Kawasaki 650 Error Code 62
Error code 62 on Kawasaki 650-series motorcycles (such as the Ninja 650, Z650, or Vulcan S 650) typically indicates a malfunction with the sub-throttle valve actuator (also called the secondary throttle actuator or STVA). This component is part of the fuel injection system and controls the sub-throttle valves to optimize airflow at low RPMs for smoother performance and emissions control. When it fails, the ECU (engine control unit) detects an out-of-range signal, open circuit, or short in the wiring, and it cuts power to the actuator to prevent damage.Common Symptoms
  • Check engine light (FI light) illuminated, often flashing.
  • Unusual buzzing, clicking, or whining noise from the throttle body area (especially on startup or shutdown) as the actuator tries to move the valves.
  • Rough idling, hesitation, or reduced power below 3,000–4,000 RPM (the bike may feel "doggy" at low speeds but run normally at higher revs).
  • High idle RPM (e.g., stuck around 4,000 RPM) or failure to return to normal idle.
  • In some cases, the bike may still start and run, but performance is compromised.
This code is common on models from 2012 onward, especially after battery work, washing the bike, or if it's been sitting unused.Possible CausesBased on service manuals and owner reports:
  1. Loose or corroded battery connections: A frequent trigger, especially after disconnecting/reconnecting the battery or using a charger/jumper. Voltage spikes or poor grounds can confuse the ECU.
  2. Wiring issues: Open/short circuits, frayed wires, or poor connections to the sub-throttle actuator (located under the airbox/throttle body).
  3. Faulty actuator motor or servo: The motor itself may be worn, seized, or out of calibration (e.g., weak spring or binding valves).
  4. Throttle position sensor (TPS) problems: Sometimes related, especially if water ingress from washing the bike affects sensors.
  5. ECU glitch: Temporary from low battery voltage, aftermarket mods (e.g., exhaust or Power Commander), or environmental factors like cold weather.
  6. Less common: Throttle body sync issues or full throttle body failure.
How to Diagnose and FixSafety note: Always work with the battery disconnected to avoid shorts. Consult your model's service manual (available online via Kawasaki's site or forums) for wiring diagrams. If you're not comfortable with electrical work, take it to a dealer.
StepActionTools NeededExpected Outcome
1. Clear the code (reset ECU)Turn key off. Disconnect negative battery cable for 10–30 minutes (or ground the positive terminal to the frame). Reconnect, start the bike, and ride 5–10 miles. Check code again (hold both buttons on dash until odometer shows codes).Wrench/screwdriverCode clears if it was a glitch (e.g., from battery issues). Common fix for 40–50% of cases.
2. Inspect battery & connectionsCheck battery voltage (should be 12.6V+ off, 13.5V+ running). Clean/tighten terminals. Test for corrosion.Multimeter, wire brushResolves if voltage was low (<12V) or connections loose.
3. Check actuator wiringLocate sub-throttle actuator (behind throttle bodies, under tank/airbox). Inspect connectors for damage, pins for corrosion, and wires for chafing. Measure resistance (should be ~1–5 ohms per manual; infinite = open circuit).Multimeter, service manualFixes wiring shorts/opens without part replacement.
4. Test actuator functionWith key on (engine off), listen for actuator movement during self-check (buzzing for 2–3 seconds). Manually cycle valves if accessible.NoneNoisy/stuck = bad actuator (~$100–200 to replace).
5. Sync throttle bodies & check TPSUse a manometer to sync mains/subs. Adjust TPS voltage (0.5–1.0V at closed throttle).Carb sync tool, multimeterAddresses related sensor drift.
6. Replace parts if neededSub-throttle actuator ($150–250 OEM). Full throttle body assembly if multiple issues ($500+).Basic toolsLast resort; test after install.
Tips
  • Aftermarket mods: If you have a full exhaust or fuel controller, ensure they're tuned properly—mismatched air/fuel can stress the system.
  • Dealer cost: Diagnostics run $100–200; fixes $200–600 depending on parts.
  • Prevention: Use a battery tender for storage, avoid high-amp chargers directly on the bike, and cover electricals when washing.
  • If the code persists with other symptoms (e.g., no-start), scan for additional codes like 11 (main TPS) or 21 (crank sensor).
