1 - 2 of 2 Posts
Hi all. Rob here from Rotorua, New Zealand. have just purchased a Vulcan EN500 for my wife to learn to ride. Have developed a small problem with possibly the starter solenoid or clutch interlock switch??
Looking for a bit of advice. I've found the starter solenoid. Can anyone tell me where the clutch lockout switch is on my bike? I've searched for forum pages & it's pretty much the identical problem as user "Gershwin" had - "My 1998 Nomad 1500 (carb) had occasional problems starting. All the lights came on but there was no action from the starter motor at all. I found I could start it by rocking it in gear so that the motor turns slightly and then starting as normal. I ruled out the clutch and side stand lock-out switches because it did start in gear and out of gear after I used the 'rock and go' method. I suspected a dodgy starter solenoid - or perhaps enough voltage to kick it into action. I have installed a new battery and it is fully charged from a trickle charger. The problem has actually become worse with 9 out of 10 starts needing the 'in gear rock on the motor method' to get the starter motor to work. This points to a fault in the starter motor or solenoid. Has anybody exeprienced this? My thinking is that I should remove the starter motor and clean the gizzards of the solenoid, which I presume is integral with the motor. Its a bugger to get to, but it is possible. Any ideas or suggestions?
Is anyone above to tell me where the Clutch interlock switch is on my EN500?? Kind regards, Rob
Welcome in Rob! Suggest you ask your questions in the 500 forum where other owners can help you out. Not all read the new intro section.
1 - 2 of 2 Posts
