I have an EJK on a Voyager. My first suggestion is, if you don't already have an EJK, get Ivan's ECU flash instead. If I had known about the flash before I got the EJK, I would have done that instead. The flash does a lot more than just control fuel, so it is the better option. The EJK works OK for me and I can't justify throwing it out and paying even more for the flash. If you have the EJK and can return it or don't mind throwing it away for something better, go with Ivan's flash.
If you already have the EJK, it may or may not help fuel economy. It didn't make much difference on mine. If your bike is stock and you plan to keep it that way, it will help drivability a little, and will make it run a little cooler. If you have aftermarket pipes, it will help a little more, but not much. If you have a BAK (Big Air Kit), it will make a much bigger difference. The BAK needs more fuel or the bike will run way too lean. Even a K&N direct drop in replacement air filter has a higher air flow than the stock filter, so adding fuel is needed even with those. Whatever you have, it will be a more responsive and run cooler if set up right.
Setting it up for your personal sweet spot will take some time. Dobeck has suggested initial settings and I could give you mine. Adjust to your personal preference from there.
