Ok, a follow up on Shoodaben Engineering Vulcan S flash.
I Do Not advise getting this unless you want FABULOUS performance and Outrageous acceleration. This is how the KVS “shoodaben” from the factory. The Goblin pulls at every RPM. I have a “country” (read approximate) 0.3 mile stretch that from a dead start I would hit 90-92 before I slowed for a sharp curve and a bridge. Usually that’s where Goblin would start pulling weaker. Tried today and hit 100 and was still pulling strong.
I was a proponent of the Boosterplug but the flash beats it hands down and is only about $70 more. Plus it is even simpler to install. Get it done and Don’t tell your buddies hehehe.
I also replaced the tires, chain and sprockets and flushed the brake fluid. Word of warning( don't ask my dumb ass how I know) DO NOT allow either fluid reservoir to go dry ESPECIALLY if you have ABS. Also I found that a small bolt between the chain and top of the countershaft sprocket makes a world of difference after you CAREFULLY bend the lock washer down ALL the way around the nut
