While removing my ecu to send into Ivan I broke the locking tab on the ecu connector that clicks and locks onto the ecu body. Is this a big problem and if so how would I go about replacing the connector female end without removing the harness. Any opinions would be appreciated
any way to zip tie it? had to do it on an old car iginition.
This may be your best option. The connector is a tight fit and likely wouldn't come loose but no use taking a chance
Thanks to dlars and allbsharp for the reply. I was looking at the connector and realized I could drill a hole in a zip tie and put it over the ecu lock fastener and run it up through the connector where I could lock it into the head of the zip tie. This seems like it would work and if I made a couple of them if I needed to remove the connector I could just snip it and reuse another fabricated zip tie. Much better than trying to glue it or replalce the connector. Thanks for the ideas.
