1 - 5 of 5 Posts
Hi,can anyone please tell me the best way to earth the radiator fan on my vn1500B 88SE. The 7in wire worked loose and I'm not sure which nuts it was secured to. Connecting to the bottom left rad mount and fan assembly doesn't seem to work. Thanks!
Welcome to the forum.
If you require a ground, run it to the frame, horn mount, etc...the original wire is 7“, gotta be a connection close. Here is the fans wiring diagram. Little tip. When I do repairs on anything, I take pictures along the way so when I come back to it can be sure how everything was. I’m not getting any younger and sometimes have those Duh moments. An online factory repair manual can be accessed at www.Manualslib.com.
Thanks very much,I'll try that! I'm getting on a bit myself so I understand those 'duh' moments! Safe riding mate!
1 - 5 of 5 Posts
