1 - 5 of 5 Posts
Banned
ok about to do the dual head light set up, each light has high and low bean, but also has a some kind of little running light bulb, is there any speical way i need to wire these and should i even worrie about hooking up the little running light
As far as I know the Running Lights in the headlight assembly were a reqiurement in some of the European countries but that may not be true in your location. I'd check with a local dealer regarding inspection requirements. If you need it just tie it in parallel with any switched power that you may have available in your headlight nacelle. The small bulbs draw a small amount of current so they shouldn't cause any wiring harness or fuse overloading problems.
Banned
Drag speicality 4.5 grooved ones got 2 of then then got the bracket off ebay waiting for it to come lights 60 each bracket 48 bucks,
1 - 5 of 5 Posts
