1 - 20 of 24 Posts
No more wimpy scooter horn for me. These bad boys are 6 inches in diameter.
Gave my wife her own drink holder.
Nice setup...don't mean to rain on your parade, but will they survive getting wet whenever you ride in the rain? :eek:
Oops. Two 120 Decibel Horns not 139 decibel. I guess I looked at too many horns before I made my choice. They are loud though.
MODEL 306-2T / 120 Decibels-345/290 Hz
They are advertized as the loudest electric horns you can buy.
The Bad Boy air horn is 118 Decibels so that will tell you how loud these electric horns are.
I have the Stebel Nautilus Air horn but could never find a place to mount it where it would be protected from water. It is 139 Decibel.
I am going to get the Stebel and mount it under the unused filter cover on the left side after I install the Thunder Air kit.
Can you run 2 horns on the 5A horn circuit? Or did you run a separate circuit to AUX power? I like the way you've got the drink holder configuration, but I have the rear speakers, so no way to do that.
On 2011 Voyager Horn Circuit is 10A, I'm almost sure you can upgrade your fuse to 10A if necessary. For these loud horns you need 10A for sure. Thanks.
Scorpo I really like the way you did 2 of the FIAMMS. I run one, but this winter will do the fairing mod the way you did. Great work and thx for pointing out that it's a 10A circuit.
I use both high and low tone.
Sent from a mobile device with a keyboard that sucks, pardon misspelled words..
I like it! Is it an easy - remove the stock and hook these up install or is there more involved?
Discussion Starter #15
The stock horn is a 10A circuit, but with two horns I wanted to use a relay for safety. The horn switch itself is usually the weak part and if you draw too much current through it you can fuse the switch.
I ran a wire with a 20A fuse to the positive terminal of the battery. Where the stock horn is located I mounted a 30A relay. I connected the stock horn wires to the switch on the relay, and put the two horns in parallel to the relay, and power from the battery to the last connector on the relay.
The horn circuit triggers the relay and the horn gets power from the battery. Can only come one when the bike is powered. Pretty easy install.
Agreed, very clean. Would like more info on mounting, and wiring.
You did the circuit the right way. Well done.
Streble air horn on relay. Not pretty but LOUD.... Wish I had one of the black ones. Rain??? Whats that? Detachable passenger cup holder using a window flag mount. Its only on there when the wife wants it. That box in the back of the trunk is an aux power point.
More details on that cup holder - PLEASE!!!!
1 - 20 of 24 Posts
