1 - 4 of 4 Posts
i put some oem driving lights on my 2010 nomad the come with 25 watt bulbs, what is the max i can put in there
im running 50w in mine. I couldnt find any 25-35w halogens bulbs locally. The 50w's depending on voltage are drawing between 3.6 - 4 amps each. Im going to try to find a pair of lights with out halogen bulbs to go in there, those u cen get in a lower wattage pretty easy.
Banned
Hi,
As far as I know, upto 60W driving lights are available but very few. Also it depends on your fuse which handles only the taillight, front running lights, license plate, instrument cluster, and the brake light etc. But if you are upgrading any of them, it will draw a lot of charge. LED's are better for on coming traffic to see and also light the road very well.
Thanks,
Anthony
you can get the H-3 base bulbs at NAPA Automotive I use the stock 35watt about 8 bucks each. I don't want to add anymore load to the charging system that's why I used them. Any Napa is where I go..Moe
1 - 4 of 4 Posts
