Somebody else just had this same problem. It was his wheel bearing.
A follow up. Sure enough the belt started squeaking again, I think because we’re finally getting some hot weather here in the PNW, so I backed off on the tension by about 2 mm and it shut up. So I guess a happy ending unless it starts squealing again.😊Yeah I’ve got the belt tension tool. To be honest, yesterday I decided to just takeoff the guards and inspect everything and clean it with water and a brush to get the dust off. It’s been a long wet winter here in the PNW. after that I just put the guards back on and said let me see how it behaves after a good cleaning. So I took a 30 mile ride and it didn’t start chirping again so I’ll just wait. If it does start to chirp I’ll back off on the tension a little.
Mine is an 06. All these bad bearings in the output shaft, and in the rear wheel, would they shut up if you change the belt tension? I’m thinking they would do it no matter what, but mine quiets when I change my belt tension.Is yours a 04 or 05? If yes, verify that the single bearing in the rear pulley hub is in perfect condition. The only way to check it for sure is to take the rear wheel off from the bike, then the pulley and pulley hub from the rear wheel.
These are sealed bearings, not actively lubed. If a sealed bearing squeaks, you replace it immediately. There is no other acceptable alternative.Mine is an 06. All these bad bearings in the output shaft, and in the rear wheel, would they shut up if you change the belt tension? I’m thinking they would do it no matter what, but mine quiets when I change my belt tension.
Yeah, I know they’re sealed bearings and I don’t think they’re squeaking. My drive belt was until I adjusted it.These are sealed bearings, not actively lubed. If a sealed bearing squeaks, you replace it immediately. There is no other acceptable alternative.
No kidding! For those that don't know how to convert inches to mm, that is a 25.4 mm deflection. Factory is 3.0 - 4.5 mm and most of us that don't use that use 7 - 10 mm.Check out this post from long ago…
Belt Chirp/Dead Horse/Belt Squeal
Belt squeal is a really common thang for our bikes, but I’d never go with 1” deflection.
So true, but did you notice the posts after that, one guy had the dealer check everything— pulleys, bearings, everything — and said everything was fine and then they set belt tension back to the factory specs and it squealed like crazy. So what, you just have to live with it or else what? The chain drive conversion seems more appealing to me today😜No kidding! For those that don't know how to convert inches to mm, that is a 25.4 mm deflection. Factory is 3.0 - 4.5 mm and most of us that don't use that use 7 - 10 mm.
Reading that post, I don't think he really had any idea just how much deflection he had or how much he had backed off the adjusters, he was just throwing out questionable numbers from memory.
Yeah, while I’m in there, cleaning and inspecting and probably tightening up the tension I’ll make sure the alignment’s what it should be too.👍It might be a long shot, but if the two adjusting bolts at the rear of the engine are not set correctly, could that change anything in the angle of the engine and make the belt noisy?
