I want to change my 2004 single bearing hub for the later double bearing hub.If anyone has done this can you please list the parts needed for the changeover.Im from Australia and with the $ so high its a good chance to buy.
cheers
bearings
you will just need the rear bearing assembly. This is the part number and price from Babbitts. Easy to do and not that $$ 42033 SKU: 42033-0020
COUPLING-ASSY,RR HUB 1 $134.08
double bearing hub
From what I was told by the dealer, 2006 models and up have the double bearing kit in the vibration damper. I have an 04 V2K, took 2 of the normal bearings out before I found the double bearing kit. No problems since.:D
Thanks for the info,just ordered from Mr Cycles,also ordered the collar part#92152A as well.
cheers
