1 - 2 of 2 Posts
2005 800 Classic
Here's a picture of my mistake
http://i.imgur.com/j3DQK0b.jpg
I was trying to remove the front spark plug for cleaning and gapping, and pulled on the spark plug cap and accidently tore off the wire from the cap and rubber off the top at the elbow.
My question is, I need a replacement cap and want to know if the cap and wire and ignition coil all come as one connected piece or can I remove the top cap at the elbow from the ignition coil wire and just order the cap?
The OEM number for front cap is 21130-1075
Ignition coil front is 21121-1245
Discussion Starter #2
ok, I found an old 2013 thread here called Spark Plug Wire
They said the coil wire and cap can come apart by twisting the cap counter-clockwise and pulling them apart, there's a brass screw inside the cap that screws inside the coil wire to hold both together.
So the answer to my question, does coil and wire and cap come all as one piece? the answer is no.
So I can go ahead now and order just the cap
1 - 2 of 2 Posts
