1 - 7 of 7 Posts
I am new to working on bikes and wanted to check my plugs. I have the original tool kit (I know, right?) however couldn't get the wrench in so I figured, 'hey let's take this cover off'. Once I realized that I shouldn't have removed the 3 bolts and did that, I immediately put them back in. My problem now is that it is leaking oil out of the bolts and from under the cover area. I have torqued the bolts down to 104 inch pounds (spec from manual) but it doesn't feel enough. Is that the real torque??
Also, do I need to buy a set of 3 new bolts for the cover? It wasn't leaking before I removed it.
Help.
Ian
The manual I have does say 104 in-lbs. My guess is your valve cover gasket is pinched somewhere, or you are perhaps missing the rubber gaskets that go underneath the three bolts. I had the valve covers off my bike earlier this week for the first time, and they are a bit tricky to get back on properly. I torqued them properly and I can't tell if I just didn't wipe some oil off afterwards or if I have a bit weeping from the gasket. Remove the bolts and check that there is a rubber gasket under them, and check that you valve cover gasket is not pinched somewhere. If that doesn't work, replace the gaskets.
Thanks for the reply. I didn't see a gasket when I pulled the chrome cover off. There is the actual head, a 'plastic' black gasket I guess then the chrome cover with the three bolts. It was leaking from the bolts and between the black 'gasket' and chrome cover.
Just be careful not to over-torque. I ended up snapping one of the head cover bolts after I checked my valves, luckily I was able to pull the threaded part with an easy-out and I happen to have a spare VN800 engine so I didn't have to order a new bolt. And yes, I was using a torque wrench, but for whatever reason it didn't click over properly, I think the required torque was too low for the wrench.
Thanks for the reply. Do I need to order new bolts since I have removed these ones? Just drives me crazy because there was no leak prior to my idiotic move of removing them.
No you shouldn't need new bolts unless you snapped one like I did. You might just need to give them an extra quarter or half turn to get the right tightness. After I broke the first bolt, I just sort of "eye-balled" them when torquing and haven't had any issues thus far. Like Beans mentioned, you might also be missing the o-rings that go between the bolts and the head cover, so make sure you have those and that they aren't broken -- part # 92055 in the diagram here: 1996 Kawasaki VULCAN 800 CLASSIC (VN800-B1) Cylinder Head Cover | Babbitts Kawasaki Partshouse
annnnnnndddd...SNAP!!!...DANG. Easy out here I come...anywho, it looks like some of the inner washers were broken so I have ordered 3 new ones as well as 2 new bolts...
Ian
1 - 7 of 7 Posts
