1 - 20 of 31 Posts
So.. My first try was about 600km ago.
I wanted to try again so i bought this filter wrench from amazon. Turn out its too damn big.
I tried to stick a wrench through the filter but it wouldnt move at all. Im not sure what kind of gorilia installed my oil filter but it just wont get out.
Any solutions? Since right now my bike is empty from oil
Sent from my ONEPLUS A5000 using Tapatalk
[ame]https://www.amazon.com/FRAM-FM101-Oil-Filter-Wrench/dp/B00FQT3SJ0[/ame]
The except part I have, worked great on the S; and 2008 Toyota Camry and 2012 Honda Accord.
Next time make sure the gasket is well lubed with fresh oil on the filter. Hand tight a 1/4 turn.
An old belt and some vice grips may work if you have room to slip the belt around the filter. Make your own belt/strap wrench. Or buy one from your local hardware store.
I can't believe that in all of Israel there aren't any Auto Parts places that have Oil Filter wrenches. I mean it is 2019 and not the Dark Ages. And once you get it off don't tighten it so damn tight. Hand tight only.
For me that is even to tight since my huge paws can crank that sucker down pretty damn tight. Whatever you do don't use a wrench to tighten the oil filter. It doesn't need it.
This is the answer. Used this method many times with screw-on filters.
Unless he really over tightened the filter. I have seen it where people super tightened filter on cars and we had it on the lift and couldn't get that sucker off even with a wrench. Had to use a blow torch to get that thing off. hand tighten only is my motto. If you are limp wristed then a quarter turn more but that is it!!
I have a pair of channel locks that open just wide enough to grab and crush that frustrating little oil filter :). I’ve been there though. Frustrating!
Discussion Starter #14
So.. An update
After a long day yeserday i tried to punch a wrench again unsuccessfully.. I went to the garage to see if i can borrow a tool to open it.. It was closed. I then went to auto depot and bought this 5 bucks strap wrench and and opened that damn filter.. It was hard to open even with the strap
TL:DR
I opened it using a strap wrench from auto depot and everything is ok now
Agreed. I've seen oil filters torn to shreds using the screwdriver method and still would not come off.
So.. An update
TL:DR
It's amazing how much traction and torque you can get with a strap wrench. I used to get the rusted caps off of compress gas cylinders with a strap wrench when nothing else would budge them. Glad you got that sucker off.
Discussion Starter #17
It was difficult to get it out as well
like really hard
and it was like 25+ degrees celsius outside
Make sure you lube the seal with motor oil before you install it hand tight.
I used a pair of channel lock pliers. Mangles the filter, but it works
1 - 20 of 31 Posts
