When you guys change the coolant, what kind of coolant do you use? Any regular parts store stuff or is there a particular type i need to get? I'm gonna be flushing the coolant along with changing the oil after my 2000+ road trip i just did from here on Washington to Fallon nv and back. Lord only knows when that was last changed
I've used Havoline DexCool Extended Life since the first coolant change. on my '07. Meets all of Kawi's specs, but some owners might be put off since it's red rather than green.
I know that when you mix the 2 colors without flushing the system, it turns really corrosive. I saw what happens first hand at the dealership my dad works at when i worked there for a summer. The stuff that came out was rusty as hell. And you could tell it was mixed
Prestone Dexcool, like above after following the great write up. I also went by the factory manual too. It was easy enough and gave me confidence that everything is in good shape.
BOTY Winner 2015!, BOTM Winner, July 2015
