· Registered
Discussion Starter · #1 ·
I getting a little coolant leakge from the draining bolt, Have anybody had this problem before it appeared that the leak was comming from the bolt but I saw some residue comming from the side too.
Here are some pictures. I clean the area before taking the pictures, my bad.
Any help will be apreciated.
Jels.
· Registered
The 'bolt' in the last picture is the oil gallery plug, not the coolant drain. There is an o-ring under that one to seal it up. That one should ONLY be removed for oil pressure testing!
The coolant drain is in the last picture of your first post, in the red circle. There should be a copper washer under the head of that bolt to seal it. Coolant can seep down the engine case then drip from the oil gallery plug.
Check the tightness of that coolant drain plug.
· Registered
Discussion Starter · #5 ·
Thank you so much that appeared to help !. tjputh that the other plug was the draining plug but know I know better. thank you for your Help I'll ride it tmorrow and instpect the leakage.
Jels.
