1 - 7 of 7 Posts
Hi all..
Well third time now got coolant on the fins,really annoying, :mad:coming from up under the tank somewhere..does any one have any ideas please? Thanks :)
its an 09 with 1500 miles on it.They said it was a loose connection last time,but I cant see why it has happened again.I seem to remember reading somewhere that this is a common thing with these bikes.
Allan,
So it was down to the Dyno run then... Not. Cheers Martyn
Well when i first had it delivered it leaked and they said loose hose clip or something.Then it did it after the dyno run a couple of weks back.Took it straight in to shop and they "fixed it"..Then it happened again last week,they did say all ok now it was a top hose which had been straining after the dyno run,well thats what they said! as long as it doesnt go again..
Mine still pops on a closed throttle, better (just) since I re mapped. I will email you the map and a printout, I would be interested to see how it compares with yours. I reconnected the air bypass valve and it makes absolutely no difference.I will drop you an email later.
1 - 7 of 7 Posts
