just got my cobra fi2000. what is everyones settings and what mods do you have? sound off please
If you call cobra and tell them what mods you have on your bike they can recomend settings for your bike.
my mods are in my signature, I'm running 2-2-0
I ran 2-2-0 zero as well with v&h pro-pipe and Baron Big Air kit. Worked great. I did eventually change to a v&h fuelpak. I think it give me more granular settings across the throttle range. I think both are fine.
After a bunch of reading I have just completed the following:
1) removed secondary butterfly valves
2) installed KN filter
3) re- tuned my Cobra fI2000r
My current setup:
- Bub Jug Hugger slash cut 2+2 (drag) with Hard Krome baffles
- K and N factory replacement filter
- Air box mod (removed lower part of inner air box)
- Factory plugs
- Cobra fi2000R
- Marble mod
- Sea level maybe 5-10'
- factory pulleys
I used the prescribed method that the Cobra help line recommended to tune (earlier thread). Damp day my, settings are 4-3-1. So far so good, their is good acceleration and pull from 3rd to 4th with very little if any hesitation when throttle is snapped open. I am believing that since I am at sea level, the abundance of oxygen in the air is going to promote higher pot settings as opposed to someone in Denver with the same set up. I still think their is some direct relationship between knowing where the peak setting of pot 1 is and the sweet spot of where 2 will end up. I don't want to run on the lean side but still looking for maximum power. I know the last POT will need a dyno to really know where it needs to be.
For tuning the #3 POT, I thought about running at highway speed (65) for a few miles, then cutting motor and coasting to stop and check the plugs, but this will be labor intensive and a patient mechanic (me) will be needed (and asbestos hands).
I still need to install NGK iridium plugs but plan on doing that once I am satisfied with the tuning.
What I have noticed is that after the K and N installed and #2 butterfly's removed, I can definitely tell a different sound at idle and at speed. At idle, the sound is like a more finished combustion, like the TO in PO-TA-TO is more complete. At crusing speed it just sounds smoother and also more finished. I am now getting very little backfiring, and was not satisfied with the times it would backfire prior to the K and N. I guess the engine was begging for more oxygen to make a complete burn on the the intake of air fuel mixture.
I love my 9 and it runs great, I just want to be sure It's running the best it can.
Any thoughts are welcome
