1 - 7 of 7 Posts
Dang...I just replaced it 6 months ago. The Kaw engineers really screwed up on this one. I think I'm going to have the push rod chrome plated so it quits tearing this gasket up.
Anyone else having to frequently replace this oil seal?
yea Bill, If it is pushed in just a little it will leak again. I changed mine out when I got the bike and it started leaking a month later. When I got my tires replaced, I ask the tech to look at it and he showed me where I went wrong, took it out and put it back the right way...no leak in a year. Hope this helps:)
By 'pushed in just a little' do you mean the seal is not seated all the way? I replaced the seal (again) this morning and found the old one had popped out of its mount hole. I think the last time I just pushed into place with my fingers. This time I used a deep well socket aand mallet to tap it firmly in place. I seated it flush with the case. That might have been why it failed. (Maybe the Kaw engineers didn't screw up after all:rolleyes:)
Also, the surface of the push rod was pitted, very rough. That would act like a file to enlarge the seal hole. I polished it smooth with some very fine wool.
Rode the bike to work and no more leak! Time will tell if it's fixed.
Just one other caution...it is possible to push seal all the way through and that will not make your day!
I was surprised there wasn't a lip inside the hole for the seal to seat up against and to prevent it from being shoved all the way through. When I saw that my first thought was 'be careful not to shove it in to far!'
Also noticed this time there is a difference in the push rod ends. The flat end gets a dab of grease and goes into the engine against the clutch and the end with a dimple sticks out to insert into the clutch servo. Just an FYI for the next guy who has to do this.
1 - 7 of 7 Posts
