1 - 5 of 5 Posts
Discussion Starter · #1 ·
Anyone know if Kury or RAM clutch or brake perch adapters will work on a Voyager? Kury's web site says no.
If not, anyone know where I can get adapters that will fit? I can't find any perch adapters that specifically say that they fit a Voyager.
I have the standard mount, and if you leave that stupid u-mount piece (the plastic one) and it slides just behind clutch reservoir and sits really nicely in there. I will try to get a picture, but I just spent 2 days modifying the bike and just put her to bed after getting it all buttoned up. I'm not going back out tonight.
Discussion Starter · #3 ·
Thanks! I think I know what you mean. I will have to look at the bike to be sure. I think that might be the way to go. At least the handlebar isn't curved there.
After I posted my question, I was in the garage and took the opportunity to look at the bike. I never noticed before that the top bolt is recessed on the handlebar clamps for the reservoirs. That must be why they are not compatible. A spacer and longer bolt would fix that if the distance between the bolts is not more than the standard mounts can span.
You should be able to tell from these photos.
Discussion Starter · #5 ·
Thanks! Tight fit, but it works.
1 - 5 of 5 Posts
