1 - 9 of 9 Posts
I'm wanting to change the spark plugs on by 900 classic lt. Does any body have pictures of how to tale off the gas tank and perform this procedure. I thought I seen it on here once.
Also, my tread on my back tire is bald right in the middle but closer to the sides is good, should I get a new tire? it has about 11000 miles on it
I'll let the other guys answer about the plugs, i haven't done that yet... too new.
As far as the tire is concerned: yes, replace it. You'll be suprised when you see the amount of rubber on the new tire compared to your bald one and how nice it feels to drive on.
Thanks for the comeback, got an appointment tom
Go to the rear of the tank and remove the bolts, then just tilt the tank forward and block it up with a piece of wood. YOu should be able to reach the plugs using the provided wrench. As for the tire, invest a couple of bucks in a tread depth gauge. At 2mm of tread, the manual says you're good for speeds up to 80 mph. However, once you reach that depth, the rest wears kinda quick. If you have a narrow strip right in the middle of the rear, I'm guessing you don't do a lot of roads with twists/turns?
Nope, not to many roads like that in Indiana. You don't have to remove the speadometer at all? Ok I'll try it , thanks
plugs
why lift the tank? Changed mine 5 times --just pull the wire off, (carefully) change the plugs---be sure to check / set gap---antisieze on the plug threads works well--don't get the anti seize on the electrode
shortdog
shortdog
Just letting others know that a little anti-seize goes a long way. Don't brush it on until you can't see threads. Just a little drop and wipe it around. I rarely use it anymore to be honest.
get iridium plugs too. They should be the last plugs you would put in this bike. Get a Metzeler ME880 tire. I love mine. Had them on my last two bikes, they cost more, but they last longer and have good traction. I don't know how big you can go on this bike. I would like to move up to 200. I have heard of guys going with 230 but they have do a fender mod.
1 - 9 of 9 Posts
