1 - 2 of 2 Posts
BOTM Winner, April 2016
How the heck do you do it???? LOL I got the wide leavers to put on, and it doesn't look as straight forward as I thought it would be
Not really hard at all.
The right side (brake) is actually really easy. Unscrew the black plastic piece from the bottom (don't lose the screw!), then unbolt the lever. It comes right off..
The clutch side.. that one is a bit more complicated, since the clutch cable is attached to it. Your going to need to loosen the cable to make some "play".
Really, the best way to do that, is to simply unbolt the housing on the OTHER end of the cable. If you look at it, you will see what I mean.
1 - 2 of 2 Posts
