1 - 19 of 19 Posts
Should i go x-ring or stay with the traditional o-ring? which brand is the better these days? any recommendations would be appreciated!!
It would be interesting to see a comparison between RWHP for o and x ring.
I used an RK X-ring last fall. Only about 1000 miles on it but its holding up super and only needed adjusted after the first 150 miles or so.
Update: Finally got the chain good and hot yesterday after pulling up some of the hocking hills twisties @ 60-65. Have a good 2" of slack now. Hopefully this adjustment will be the last for a while.
what size/count chain do we have? i'm getting a bunch of different answers in googling and filtering for vn800 on online shops.
I believe the 1st couple years with the 46 tooth rear sprocket use 114 links, all others use 112.
Banned
I need a new 530 chain for my 2005 800. The front and rear sprockets are 17/41 and the old chain has 112 links and has a clip master link.
I read where if you remove the clip to not reuse it but buy a new one cause it weakens when removed.
I heard about rivet type master link chains, do those chains come with the rivet master link already connected? Or do you have to rivet the master link yourself.
Every one I've bought has came with a rivet link. To assemble, you can use 2 hammers. Place behind link to hold it and hit the outer part of link to mushroom the pin to lock the link together. You can also buy a tool to put these together. I used the hammer method 2 years ago instead of buying the clip link separately.
Banned
So when buying a chain they come with the master link already attached with the chain in continuous loop or de-attached and you have to attach the master link yourself?
The chain is not continuous, just a single length and a master link. I'd recommend the rivet tool if you have never done it before, but 2 hammers also works. Clip type master links are usually not recommended for a motorcycle for safety reasons but there are folks that use them.
Banned
if I order a bikemaster chain from BikeBandit will the chain include a rivet master link or is the master links sold separately from the chain
Banned
oh wait, just read the specs on that rivet tool above and it says something about hollow nose and solid nose master links, what's those?
1 - 19 of 19 Posts
