I always find it hard to find all the information I'm looking for in one place when working on something so I thought I'd write everything down here for anyone working on them in the future.
The drive sprocket cover has a single bolt on the rear of the cover, hex key, and then the whole cover slides to the rear to come off.
Stock sprockets are 17/42. People have modded to 18/39 for lower rpm. I've even seen a post about 19 fitting but cannot confirm.
Standard chain length is 112 links.
Sockets needed: 27, 19, 17, 14, 12 and I used an adjustable wrench for the rear axle nut since my pipes were in the way for a socket.
Rear axle has a pin that must be removed prior to removing the nut and don't forget to flatten the locking washer on the front sprocket nut.
If someone has torque specs, I'll add them to this post.
Let me know if I forgot anything.
