1 - 7 of 7 Posts
Hi All.
I picked up a new to me 2009 Vulcan 500 today. About a 2 hour ride home on the trailer. It's in real nice shape, less than 2300 miles. I'm going to go through some routine maintenance in the next week or two and I have a couple of questions.
Since the bike doesnt have a center stand, can somebody recommend a motorcycle stand that will fit the rear? Are they all pretty much the same or is there a specific type needed?
The bike also has some type of fittings on the triple tree, I think they were used for a windshield, but hopefully someone can recognize it? I'll probably put some type of screen on it, more curious than anything else.
Here are a few more pics:
Thanks for the reply. I think those brackets are from a memphis shades windscreen, supposed to be a type of quick release system. Would have been nice to have that screen, but I put a national cycles version on it instead. Blocks the wind some, so it helps at 55.
I also picked up a front wheel chock for about 50 from Amazon. Actually works pretty well, holds the bike mostly vertical which helps in the tight confines where its parked.
The fittings on the tree are definitely for a windshield. I bought a stand that was pretty cheap, and does the job.
ZENY 1100 LB Motorcycle Center Scissor Lift Jack Hoist Stand Bikes ATVs Scooter Crank Stand https://www.amazon.com/dp/B01860HLCU/ref=cm_sw_r_cp_apa_LF1WBbGAVTY6E
Sent from my SM-N950U using Tapatalk
Now that is a slick jack! Haven't seen that one before. I have the hydraulic lift from Harbor Freight that works really well but it's big and heavy. Takes up a lot of space. I also have the swing arm lift from Harbor Freight. It works but the brackets suck. They bend and just don't fit this bike well. I seldom use it any more.
I like that chock. How secure is it? Looks like it could be pretty useful on my porch where I park mine
It's pretty stable, not hard to roll the front wheel up under power or not. Has rubber feet so it doesnt slide around much if at all.
1 - 7 of 7 Posts
