1 - 20 of 20 Posts
Happy Thanksgiving to all. Well, this AM the weather was beautiful, so I went for a ride on a just-opened highway. After I exited and was rolling to a stop at light, I downshifted out of sequence (without the clutch fully engaged). I felt an understandably heavier shift but thought nothing of it until I began to release the clutch when the light turned green. Lots of noise, no joy. I quickly pulled over and checked everything. It all looked fine, until I noticed that a belt was lying about 50 ft behind me on the road. Sure enough, it was mine, with a clean break! On the plus side, even though 5 bikers (and a cop) passed me by in the hour I was standing there, an HD rider circled around to check on me just as a very nice fellow stopped his p/u truck to offer his assistance. He had a ramp and some ropes, so the 3 of us pushed the bike up, and he took me home. I was waiting for a tow from Progressive (outstanding service, BTW), who couldn't find a tow operator open. As luck would have it, they called to tell me they found someone literally as I was pulling the side stand down after we heaved the bike onto the back of Willie's truck, so I cancelled the call.
The bike is a 2008 900 Custom with 4001 miles on it, which I bought and checked out thoroughly about 4 weeks ago. The belt's teeth were perfect, with no indications of excessive wear. It just snapped in 2.
Someone please tell me that belt-drives are more reliable than this. Also, the best price I can find for a new belt is $310. Does anyone know of a place that might do better? Thanks.
I wonder if you somehow got a rock caught up between the belt and pulley. It'll cause a break like that. Unless somehow you got a defective belt, no way the 900 has enough power to snap the drive belt. The other thought is that maybe the previous owner put some miles on it, then just let it sit and the belt material got dried and brittle and just snapped under load. It could be difficult to tell if that was the case.
My belt has 32000 miles on it now with no much wear showing, so it just may be a fluke....Sorry about the ruined day....
V2K Rogue Wrangler
Is it still under warranty? Is the belt even a warranty item? When I bought my bike used, I found out that the original owner had purchased the full extended warranty, and it transfers to the next owner! The dealer I bought it from didn't even know that. I plugged the VIN into the Kawasaki website and found out. Mine is a 2007 V2K and the extended warranty is still good for a couple more years! SWEET!
BOTM Winner, December 2013
belts are not a warranty item....like brake pads,clutch and light bulbs they are concidered a wear item
I am the third owner. The first put about 3K miles on it, the second only about 800 (even though he owned it for 2.5 years, he didn't ride much). The idea about the extended warranty is a good one for future reference.
The belt looked brand new - the teeth were all clean and intact, and the tension was right on spec. I guess it could have been defective, or the break could have been caused by a stone. I finally found a belt for $280 - plus $21.50 rip-off shipping, of course, but still less than the others. Now I have one more project to do, along with changing my car's brakes.
I have the service manual, and the belt replacement looks pretty straightforward - are there any tricks or shortcuts to minimize parts removal?
I don't think the manual mentions this, but you have to remove the swing arm to get the new belt on. Not sure why they leave that detail out of the manual, maybe they figure its already off.
Crazyj, I'm just guessing, but one clue may be that you were riding on a "just opened highway". A new road surface is more like to have small stones on it and you are more likely to pick one up and flip it toward the belt. You were not on a gravel road, but it might not have been as clean as a regular highway. Just a thought. Let this be the last belt you have to replace. Tom
almost 50,000 miles on my 06 classic nine with original belt,was a fluke it happened with that amount of miles on it. Unless you can find a good belt on Ebay for cheap,the cheapest I found one is where I usually get my oem parts from is RonAyermotorsports.com .Used to use cheapcycleparts.com but Ron Ayers is cheaper at $280.00
$311.65 at cheapcycleparts.com ... http://cheapcycleparts.com/model_years/2712-kawasaki-2008-vulcan-900-custom-vn900-c8f/assemblies/76484 so the price seems to be in the ball park ... nice that someone stopped to help.
Check here,
http://www.riveraengineering.com/index.html
You can find your belt in the catalog under carbon core final drive belts.
If you know the width and the number of teeth you can get a good carbon fiber belt there. They are a distributor for Gates belts. Use the dealer locater and find a dealer near you, the belt will be about $150.
You can get the Goodyear Falcon carbon fiber belts from belt drives for a little less then the Gates belts.
http://bdlsales.3dcartstores.com/Carbon-Fiber-Falcon-SPC-Belts_c_773.html
I have no idea why your old belt broke but the carbon fiber belts are pretty tough!
James
wocka, wocka, wocka
I noticed that a belt was lying about 50 ft behind me on the road. Sure enough, it was mine, with a clean break! .
cj,, these kind of drive belts are used on skoots and motorsleds (snomachines) and all kinds of industrial machines because they are tuff and can go the distance, last long. you should expect well over 100k miles on a belt that is not abused. As for stones breaking your belt,, it would take a whole truk load of them in there at the same time or one Humongous one to cause it to break.and it would show signs of that, not a clean break. If you can study the break on the belt it will most likely point to the failure,, because you say it is a Clean Break, am assuming its in a valley between teeth, would say some(one)thing cut it or it is a DEFECTIVE FAILURE. Regardless of your current warranty situation, this is something the Belt Mfg needs to know about. The dealer and kaw may have no or little interest,, but the Mfg needs to know if there is a manufacturing defect,, as there would be more of these failures waiting to happen. 4k miles isnt even break in service for these belts.
If this happened to me I would try to find a email contact such as [email protected] of belt and talk to someone about the belt. Hopefully they could tell you who to send the belt to for observation. Chances are you could get an explanation and possibly a new belt. Worth a shot anyway.
Check here,
James
Hey, thanks for sharing that info, $150 is a whole lot cheaper than $310
Discussion Starter #16
Can't say for sure about the reason for the break; the highway was absolutely pristine - looked as if it had been swept with a broom. Actually, the break happened about 90 seconds after leaving the highway; more likely, a stone from the street I exited onto was the culprit. I guess I'll never know. I am happy that the break didn't happen while moving at highway speed, especially on a curve. The unloading of the rear tire would've used up a lot of traction and been a challenge to manage.
If that happened to me, considering the "clean break" and low service miles, I wouldn't rule out those envious of nice bikes as well as probably ex-gfs. But that's just me and my 2c. :)
Discussion Starter #19
Not unless someone broke into my shed (the bike hasn't even been parked anywhere without me standing next to it, since I just got it a few weeks ago and haven't ridden it much), sabotaged the belt, and then locked everything up again. The ex-GF idea is interesting, but in 25 years, my wife has never let me date, LOL.
When will you belt guys learn! A belt drive is the high class city cousin of the chain.
Viva the SHAFT drive!!
1 - 20 of 20 Posts
