1 - 3 of 3 Posts
replaced brakes on front and the outside pad will not stay in place once bike is rode for a few miles it falls down hanging by the bottom rod. cannot see what is suppose to keep it in place. has anyone else had this problem?
Super Moderator
Welcome to the forum from North Carolina. Happy you decided to join us. Do not own your model, but maybe this might help. Here is a parts diagram of the front brakes. Check and make sure you have all he components and they are correctly assembled. Did you use OEM brake pads? If not check the pads against your old ones and make sure they are exactly the same. Double check the spring pad (illustration number 92144A) to make sure the little tab is on it. Thanks again for becoming a member of the forum. Be well and Ride Safely.
'05 800B
1 of the pads slide on the pin to stay in place and the other pad stays in place by its extruding lip
1 - 3 of 3 Posts
