My front brake oil looked like French pressed coffee so I decided to bleed it in order to replace it with new brake fluid. I've never done this before but I have seen others do it. I thought I knew what I was doing and my front brake lever is now soft. I started by opening the nipple on the caliper. I then pressed the brake lever to release some brake fluid. A squirt of oil shot out of the nipple. While keeping the lever closed in, I then closed the nipple. I pumped the brake lever a few times and then repeated the process. I had fresh brake fluid readily available and tried to avoid letting the reservoir being exposed to air, but I believe I did.
I attempted to pump the brake a few times while the nipple was closed and then opening the nipple while the brake lever was held in. Only a sad stream of oil falls out as opposed to a straight squirt. I tried this a couple of times and still cannot get the lever to firm up with pressure. Also, I do not see the air bubble floating up in the reservoir as I pump the lever although the new brake oil has been flowing through the nipple. Nothing appears to happen to the oil when I apply the brake. What am I doing wrong??
