1 - 7 of 7 Posts
while changing the oil i bumped the wire out of the regulator on the bottom and shorted it to my high way bar. now nothing works is there a main fuse from the battery to the regulator. or does someone have a wiring schematic.
I tried searching but someones infinite wisdom involving the plugin box where you have to enter the answer, well i have mac and that plugin does not work so SOL.
Yes, there is a main fuse. I believe if you take off the left side cover below the seat, the starter relay is there and there is a fuse somewhere in that assembly. I have a service manual...let me see if I can find the specifics.
Edit: Yes, here it is...at least on a 2008, anyway.
I think the rubber cover on top of that relay just comes off and the fuse is plugged in next to it under than rubber cover. From memory...which fails me sometimes.
Don't leave us a hanging! What was wrong?
IT was just the main fuse was blown i figured that was the problem i just could not locate it with out a little help.
But i do think i am going to have to address the voltage regulator location. I put the Cobra FAtty bars on they came with a relocation kit for the regulators but it puts the wires at a sharp angle pulling on the connectors, the wires could be a hair longer would be all right.
1 - 7 of 7 Posts
