Hello all,
I was wondering if anyone had the issue I had today. Started the bike in the morning, no problem drove it for 30 some odd miles parked it a few about 5 hours later went to start it and it would not start. I check the following, the battery fully charged, the off switch in the correct position (run), tried to push start it in 2nd gear did not start and did not even sound like it wanted to start. I tried starting it with the clutch in, the bike in neutral, kickstand up ~ nothing, The started did not even engage all I had was a low sound of the fuel pump running it was not as loud as it normally is. All the gauges would cycle through the pre-start up as normal every time. I tried hitting the started while another person tried to start the bike ~ nothing. then as I was about to give up I hopped onto the bike put the kickstand up pulled in the clutch the bike was in neutral and all of a sudden it came to life and started. I shut it off and restarted it with no problem. drove it home with no issues. Shut the bike down and restarted and it started.
Any Ideas?
Thanks in advance
Bob
Any Ideas?
Thanks in advance
Bob
