but you don't need SN, or SH or SL, actually you don't need API anything, all you need is JASO, you don't need JASO with SN,SM,SH whatever
let me explain
the API ratings are for oils that contain moly, or some portions of moly, they are in those API rated oil to conform to energy conserving of gas, so they put slippery moly in the API spec oils
but you don't want moly in your bike, no, because that is going to slip your clutch plates, what you want in your bike is no moly at all, you don't want to put API SN in your bike
what you want is friction in your oil, so that your clutch plates don't get slick and start slipping
the JASO specs is for those oils that contain friction, which is what you want in your bike
the new Rotella T6 15w40 is JASO rated which means it has friction in the oil, this kind of diesel oil is what you want, not SN oil, so forget about SN or SH or SL, those are for cars for energy conserving motors, which means slip slip your clutch plates if you use them
