1 - 5 of 5 Posts
so my tipped over on the trailer about a year ago... needless to say the front right peg is now slightly bent up.. any one know where to find cheap replacement parts or a way to bend this front bracket back to shape?
All you need is to take the bracket off and put it in a vice and use a torch and heat it up and rebend it. Also check were the bracket bolts to the frame to see if the frame bracket that holds the nuts is not bent. If it is you can flaten it out with a hammer. Hope this helps been there done that.
ebay is probably your best bet
1 - 5 of 5 Posts
