1 - 3 of 3 Posts
Hi Chaps,
Well two weeks to go then my VN900 custom is on the road (legally that is)
One issue I have is with the battery. When I put the key in & then turn it, all the lights come on & it does the self test thing. The indicators, brake lights etc are all OK
When I press the start button however, the engine doesn't cough or kick over or anything. It just makes a sound similar to this, the 2nd time this guy starts his 900:
http://www.youtube.com/watch?v=6U__A9uRL-8&feature=youtu.be
My driveway is on a bit of an angle & I can successfully "Clutch" start her while rolling down the driveway.
Ideally I'd like to get this fixed before I have my full license, any suggestions?
Go for a big big ride without stopping or getting off to charge the battery & if so how long?
Or a new battery altogether perhaps?
Or just charge it? I do have a charger should I set it to 6 or 12 volts?
Or any other suggestions?
Thanks!!
Vince
If it's clicking noise then it's probably just the battery low or not good connections in the starter circuit.
Try charging first (12V) and checking the connections.
Hi Chaps,
Thanks!!
Vince
Do not use a charger that is meant for a car or truck. Find a trickle charger and only charge it for a couple of hours. Better to use a smart charger. Check the connections to the battery. Use a socket wrench not a screwdriver. Nice and snug. Borrow a volt meter and check the battery about an hour after you take it off of charge. The voltage should be above 12.6 VDC.
1 - 3 of 3 Posts
