1 - 8 of 8 Posts
Hey all I have an 09 classic 900 and have noticed my stock fuel cap gasket is all cracked up. I searched for a replacement gasket, but found out that u have to buy gas cap and all. The new cap and gasket costs 95 bucks! That and I will have two keys to mess with (1 ignition and 1 fuel cap).
Well I have searched and stumbled across a barons low profile gas cap and was wondering what you guys and gals thought about their product?
I have absolutely no experience with the Barons LP spin-on gas cap. It looks like you need to epoxy some weird threaded thingy into your filler to get this low-profile cap to spin into. You wouldn't find me doing that to my tank.
In addition, it looks to be about $90. And it does not LOCK. I'm not sure how that's a savings over the OEM cap.
Yes, having 2 keys would be a pain, but it might beat some moron dumping sugar in your open gas tank some night while your bike sits waiting for you.
If I were you, I'd figure out a way to fix/replace the cracked gasket on your original cap.
Check with your local locksmith they may be able to re key the lock on the new gas cap to use your original keys.
BOTM Winner, June 2015
I agree with Shadow. You can find gasket material pretty cheap and cut out a new gasket and bond it to your current gas cap and would be a much more economical fix without the hassle of re-keying a new OEM cap or having multiple keys. I also wouldn't mess with epoxying a new piece into my tank. Too much could go wrong if it's not done properly.
Thanks everyone for the replies! I had no clue that u had to epoxy that barons cap in! That's definetly not gonna be happening! As far as gasket material what kind of material would u guys suggest?
You can do a search for gasket material sheet and find what you're looking for. Just find something that looks to be about the same as what's on the filler cap. Usually costs around 5 bucks a sheet if I remember correctly.
OK so the Barons cap is like 75 to 85 bucks and the OEM is 95 bucks?
So for 10 bucks difference I would just order the OEM cap and reference your key code then they will send one that is keyed to your key.
1 - 8 of 8 Posts
